Tokens aren't in the library. "Hidden?!"
  • July 26, 2024
  • 4 replies
  • 187 views
Roland_Dombi
I have a library with defined variables - primitives and tokens. None of them is “hidden”, but when I import the library to a design file I see only a part of the primitives, but none of the tokens. It says they are hidden but they are not. Any idea? Thanks! 🙏
Gayani_S
  • July 29, 2024
Hey @Roland_Dombi, thank you for reaching out!
Hmm, I am not sure what could cause this, let me ask the team internally and get back to you asap.
Appreciate your patience in the meantime!
Gayani_S
  • July 29, 2024
Can you please check if the variables are hidden from publishing?
Please check out our Help Center article for more information:
https://help.figma.com/hc/en-us/articles/360039238193-Hide-styles-components-and-variables-when-publishing#h_01HD20M7HS9044NHB2YBJNE9C2.
Please let me know if this is not your case, I’ll submit a support ticket on your behalf.
Joel12
  • December 3, 2024
I had exactly the same problem. To solve this, simply rename your collection of primitives and tokens with a capital letter. (Tokens instead of tokens).
Roland_Dombi
Hey man, this is a life saver - it worked! Thank you 🙏
