I tried looking for the answer for this since I’m sure it’s a simple fix and just something I’m missing but when creating component sets if you take a variant and resize it THEN switch the properties to select a different variant there variant get’s stretched
Example/
I’m assuming there is an option in the first step of creating the component set that fixes this. I know there is a reset size button and also if you change the properties prior to the size it’s totally fine. Thank you all in advance for any help!
