Text Styles loosing its variables in Instance Components
  • October 4, 2024
  • 6 replies
  • 140 views
Vytautas_Grizas
We noticed something strange started happening in Figma with Text Styles. Fonts started too loose its weight and width variables.
Vytautas_Grizas
Also this. It does this on its own, we just watch it dance… We tried clearing Cache and reapliying variables with no success.
Vytautas_Grizas
Seems like the bug is related to Variable Font Axis, if i set them and try to edit text, the text instantly looses the the variable font axis and reset to either “regular” or “medium”. But we need “font-width: 106”, “font-weight: 550”
Vytautas_Grizas
After further testing, it seems that issue is only present when the Font Variable Axis are being used in Text Style. When the text style is detached, there is no issues.
Marco48
  • October 8, 2024
Hi Vytautas_Grizas, we are having the same problem and can’t figure out whether it is a bug or a problem with the variables/styles in the instance. We are waiting fo someone to give us a solution, hoping that there is!!
  • October 9, 2024
Hey @Vytautas_Grizas , sorry to hear you are having issues! I see in the backend that the technical quality specialist is investigating your issue, your support ticket is 1140630. Please continue working with our support team over there.
@Marco48 If you would like our support team to investigate it further your specific case, please reach out to them directly: here Thank you
  • October 17, 2024
Have you solved this problem?
