Export jpg but end up with pdf
  • August 9, 2024
  • 16 views
I’m using Figma batch export all the images, the export setting is jpg but end up with pdf
My setting
end up with pdf
ksn
  • August 28, 2024
Hey @Russ - apologies for the late reply, but did you end up figuring out what was happening here?
I tested exporting on my end, and I got the expected behavior.
I’m not quite sure the flow is working for you, since I see in your first screenshot the name of one frame, but then in your second, I see different names of the exports. Can you send a screen recording? I want to be sure you have the right export settings for each frame you’re trying to export to jpg.
