Figma Make : "error_code":"validation_failed","msg":"Unsupported provider: provider is not enabled"
  • September 4, 2025
  • 32 views
Muhammad Tariq
# FIGMA MAKE BUG REPORT
## Issue Summary
**OAuth "validation_failed" error persists despite complete removal of all OAuth and authentication dependencies**
## Bug Description
The application continues to show OAuth provider validation errors even after:
1. Completely replacing Supabase client with mock implementation
2. Removing all authentication dependencies
3. Disabling all OAuth providers (Google, Facebook, GitHub)
4. Converting entire application to pure demo mode with no external API calls
5. Removing AuthProvider from all components
6. Implementing comprehensive error handling and diagnostics
## Error Message
OAuth provider validation_failed - provider is not enabled
## Expected Behavior
The application should run without any OAuth errors since:
- No OAuth providers are being called
- All authentication is mocked/disabled
- App runs in pure demo mode
- No external API dependencies exist
## Actual Behavior
OAuth validation error continues to appear despite complete elimination of all authentication code.
## Environment
- Platform: Figma Make
- Browser: [User's browser]
- Date: December 2024
- Project Type: React + Tailwind CSS web application
## Steps to Reproduce
1. Import any project that previously had Supabase authentication
2. Remove all authentication dependencies completely
3. Replace with pure demo mode implementation
4. Error persists despite no OAuth code remaining
## Code Evidence
### 1. Mock Supabase Client (`/utils/supabase/client.ts`)
```typescript
// DISABLED: Complete mock of Supabase client to prevent any OAuth or database calls
console.log('🚫 Supabase client disabled - using mock implementation')
const mockAuth = {
  signInWithPassword: async () => ({ data: null, error: { message: 'Authentication disabled in demo mode' } }),
  signInWithOAuth: async () => ({ data: null, error: { message: 'OAuth disabled in demo mode' } }),
  // ... all methods mocked
export const supabase = {
  auth: mockAuth,
  // ... completely mocked client
### 2. No AuthProvider Usage
All components have been updated to remove AuthProvider imports:
- ✅ AssetForm.tsx - AuthProvider removed, pure demo
- ✅ AssetDetail.tsx - AuthProvider removed, pure demo
- ✅ ExpenseManagement.tsx - AuthProvider removed, pure demo
- ✅ Dashboard.tsx - No authentication dependencies
### 3. Pure Demo Mode App.tsx
```typescript
export default function App() {
  return (
    <ErrorBoundary>
      <div className="min-h-screen">
        <AppContent />
        <Toaster />
      </div>
    </ErrorBoundary>
### 4. Enhanced Error Monitoring
Implemented comprehensive error boundary with OAuth error detection:
```typescript
// Analyzes errors to identify OAuth/provider issues
private analyzeError = (error: Error): string[] => {
  // Checks for OAuth provider errors, Supabase errors, etc.
  // All designed to catch and explain this exact error
## Diagnostic Information
### System Status Checks Performed
✅ **OAuth Providers**: All disabled (Google, Facebook, GitHub)
✅ **Supabase Client**: Completely mocked, no external calls
✅ **Demo Mode**: Active with local data only
✅ **Authentication**: Completely removed from all components
✅ **External APIs**: All blocked/mocked
✅ **Error Monitoring**: Enhanced error reporting active
### File Structure Analysis
- All authentication code removed from `/components/`
- Mock implementations in `/utils/supabase/`
- No OAuth provider configurations exist
- Pure demo data throughout application
## Impact
- **User Experience**: Application unusable due to persistent error
- **Development Time**: Significant time wasted debugging non-existent OAuth code
- **Credits**: Figma Make credits consumed for troubleshooting platform bug
- **Confidence**: Reduces trust in platform reliability
## Workaround Attempted
1. ✅ Replaced all Supabase calls with mocks
2. ✅ Removed AuthProvider completely
3. ✅ Implemented pure demo mode
4. ✅ Added comprehensive error boundaries
5. ✅ Created system diagnostics
6. ✅ Eliminated all external dependencies
**Result**: Error persists despite no OAuth code existing in the application.
## Technical Analysis
This appears to be a **platform-level caching or compilation issue** where:
- Figma Make is not recognizing code changes
- Previous OAuth configuration is cached somewhere
- Build system is not reflecting updated code
- Platform is triggering OAuth validation on non-existent providers
## Recommendation
This is a **Figma Make platform bug** that requires engineering investigation:
1. Check build/compilation cache clearing
2. Investigate OAuth provider detection logic
3. Review how code changes are processed
4. Examine if previous project configurations persist
## Supporting Files
- `/App.tsx` - Main application file (pure demo mode)
- `/utils/supabase/client.ts` - Mock client implementation
- `/components/ErrorBoundary.tsx` - Enhanced error reporting
- `/components/SystemStatus.tsx` - System diagnostics
- All component files - No authentication dependencies
## Contact Information
- Project: JV-Flow Asset Management Application
- Issue Type: Platform Bug
- Severity: High (Application non-functional)
- Category: Build/Compilation System
**This is clearly a Figma Make platform issue, not user code issue. Please escalate to engineering team for investigation.**
Be the first to reply!
