I am using the figma mcp’s get_image config for the image is as follows
when i click on a node and select copy as png the image is clear crisp but when i use mcp to export the image its blurry and not so great
Hey ​@suresh.vellingiri - sorry for the quality inconsistently. Could you attach a full-screen recording that shows all the actions you’re taking through the export of your image?
Or are you able to show how the node looks when you copy, and then show me what it looks like after it is exported? Let me know - thanks!
After exporting it via MCP:
When we copy it via figma directly
Got it - thank you! I just touched base with our technical quality team, and they actually want to take a look at what you’re trying to export directly. This will help debug and/or provide info on how to adjust this, since it’s hard to tell based off screenshots alone.
When you have a second, can you please fill out this form here? If you could also share edit access to the file your exports are coming from with, along with the file name name, we’d greatly appreciate it. You can share that with support-share@figma.com, and you won’t be charged for that.
If you can’t share the file, no worries -- they can still try to help. Let me know once you’ve filled out that form, and I’ll get your ticket escalated.
I have filled the form and have submitted it. Unfortunately i cant give edit access. But have shared the readonly link
Thanks ​@suresh.vellingiri - I see that your ticket is now being looked at by technical quality team. They will follow up.
Appreciate your patience!
