Answer
FIX being rolled out by Adobe: Issue with copying vector shapes from illustrator to Figma 2025 (MAC)
  • August 1, 2025
  • 12 replies
  • 1090 views
JipJ
HI,
Yesterday all of a sudden I couldn’t copy and paste vector shapes from Adobe illustrator to Figma anymore… When is copy from Illustrator the shape now changes to an image file instead of an SVG. I have restarted my Macbook restarted Figma and illustrator, run the latest update of Figma but nothing works.
This really slows down my proces because I now have to export each vector and import it manually in Figma.
Can someone please help me with this problem.
Best answer by djv
Hey All, thank you for your patience while our team worked towards a solution with Adobe!
Adobe identified the root cause and now have a fix in place. The issue stems from a code change introduced in version 29.8.x and is not related to the recent SVG settings change. They also confirmed the exact repro: the issue occurs when the SVG “Minify” option is enabled.
They will be disabling the feature flag associated with this code change and will let us know once it’s complete. After the flag is turned off, you will need to restart the application and Copy/Paste with the Include SVG setting enabled to ensure it will work as expected.
You can find the setting under File > Export for Screens, and hit the little settings icon in that Dialog...go down to SVG and uncheck minify (until the fix has been fully rolled out by Adobe).
Gaétan PICAULT
Same trouble anyone who has the answer?
Romy23
  • August 4, 2025
I’ve also had a similar issue? Is someone able to help with this.
kylietyloo
  • August 5, 2025
I ran into the same issue and installing an older version of Illustrator resolved it. Hope this helps.
StressCreative
Its an illustrator 29.7.1 change, just go into preferences and turn on “Include SVG Code” should be gucci, I am now gucci.
JipJ
  • August 8, 2025
Thank you! ​@StressCreative, This worked! I can now import the SVG’s back in to Figma.
Bojan_Sandic
  • September 24, 2025
This doesn’t work seems like its bugged
Rob27
I am with Bojan_Sandic on this one.
Running…
Illustrator 29.8.1
Figma 125.8.8
I have Include SVG code checked and it still doesn’t work.
My pictures copy across as a pixel image.
justicart
  • September 25, 2025
Same issue, not working with any steps above.
Mac OS Tahoe
Illustrator 29.8.1
Figma 125.8.8
Copy in Illustrator, paste in Figma as pixels, paste back in Illustrator as paths.
EDIT: I was able to paste paths in figma web
Rob27
  • September 29, 2025
I can copy a vector shape from Illustrator to Figma providing it’s one layer.
Rafael Empinotti
Changing Clipboard Handling preferences and checking 'Include SVG code' in illustrator no longer works
Illustrator Version: 29.8.1
Figma Version: 125.8.8
  • October 3, 2025
Rob27
  • October 6, 2025
Thank you djv, I unchecked ‘Minify’ and now I can copy/paste straight to Figma
