Images turn into black squares and only in mobile browsers
  • August 1, 2025
  • 73 views
Vladimir3
I have designed a website in Figma Sites. But after publishing I found that some images are not displayed, only black squares. The problem is only on mobile browsers (Chrome and Safari). In addition, if I minimize and maximize the browser a couple of times, the image will appear, but only the one that was in the visibility zone.
There is a feeling that this is a bug, some kind of optimization that should have displayed the image only when viewing.
Help me find a solution!
Website — joycast.ai.
Stephen Calvillo
I’m having same issue. Only for some images though. Looks like your images are loading now though?
florian.udrisard
+1 same issue…
Works fine on desktop in responsive mode to test the mobile.
But on the iPhone itself, random black squares instead of images…
I tried reducing the size of the images but still the same problem...
  • August 15, 2025
Hey All, thanks for reaching out about this!
@Vladimir3 - it looks like support was able to help you out with this on ticket #1456237.
To help close the loop, support is able to view images as expected on mobile with the most recent iOS. This issue seems to be related to using the iOS 26 beta.
Images should work correctly on released OS and iOS versions, but we have a current compatibility issue with the iOS 26 beta version. Since beta versions can often have unexpected behaviors, we recommend using a stable OS release for the best experience with Figma Sites. Hope this helps!
