My Make workspace has crashed. I asked Claude Sonnet 4 to create a more tech-style design for my page, and I believe it added too many elements when generating the landing page. Now everything is stuck, the page won’t load, Make is completely unresponsive, and when I try to revert to a previous version, nothing happens. This is urgent. Please help me fix this or show me how to solve it myself.
Just to clarify, this is not an issue with my computer. I’m using a high-end setup with a 4060 Ti GPU, and everything else works perfectly, including programming other pages.
Thank you in advance.
Hi ​@Matheus Dayrell
I understand you're experiencing an issue where your Figma Make file is unresponsive.
To allow our team to investigate this further, could you please fill out this quick form?:  https://figma.bot/submitreport .
In the form, please share the URL of the file where you're seeing this issue and grant edit access to support-share@figma.com. (Please rest assured that granting this access will not impact your billing.)
This access will help us reproduce and investigate the problem more effectively.
Thanks for the reply, my friend, I’ve already sorted it out. I ended up coding it myself and it worked. Appreciate it, and have a great day!
