"Paste limit reached" at 23 cells when importing CSV into FigJam
  • July 18, 2025
  • 54 views
Haley Mitchell
I am trying to import a .csv with 500 cells (the alleged FigJam table limit) into FigJam to convert to stickies, but whenever I try to import it, it says “partial paste successful – table limit size reached” after pasting only 23 cells. Is there something I’m missing?
  • July 29, 2025
Hey ​@Haley Mitchell, thanks for flagging this!
This definitely sounds like a bug, since 500 cells is the FigJam limit. Have you had any trouble importing before? Are you able to share your FigJam file and a copy of the .csv with our technical quality team here? https://help.figma.com/hc/en-us/requests/new
Be sure to use your Figma email address and add support-share@figma.com as an editor (don’t worry this won’t affect your billing). We’ll have our team take a closer look as to what might be causing this issue.
David Weatherwax
Was this ever resolved?  I’m having a very similar issue.  Paste dialog says I can import 1500 cells, but only 72 cells are importing.
Haley Mitchell
  • September 8, 2025
@David Weatherwax unfortunately it wasn’t! I just played around and found out I could paste about 250 cells at a time without a problem. Go figure.
