Option + Command + A is the only shortcut that doesn’t work on my Macbook Pro 2024 (Sequoia). Clicking on the button on the right-hand side panel works.
All other shortcuts involved the Option + Command + [any key] works though.
Hi there, thanks for flagging this! This sounds odd, especially since other Option + Command + [key]
shortcuts are working as expected.
Does this happen in the browser, the desktop app, or both? If you haven’t already, try force-quitting and restarting Figma to see if that helps.
It’s possible this could be related to a system-level shortcut conflict in macOS Sequoia but it would be great to investigate it further. Since the button in the right-hand panel still works, at least you're not blocked but I’d recommend submitting a bug report so our team can investigate further.
If possible, include your macOS version and a short screen recording of the issue that really helps us dig in. Thanks again for reporting this!
I found the app that was using the same shortcut for screen capture… The problem is solved. Thank you for your attention to this!
Great! Thanks for letting me know. I’ve gone ahead and marked as solved the topic, thank you 🙂
