VS Code Version 1.102.0 (latest) doesn't work with Figma MCP.
  • July 15, 2025
  • 7 replies
  • 641 views
JayHawq
Figma MCP server worked great with VS Code version 1.101.0 but in version 1.102.0, microsoft has moved MCP configuration to a new file named mcp.json instead of previous settings.json file.  After doing all the configuration, the Figma MCP server tools do not show up under tools and the agent is unable to use Figma MCP server.
Has anyone had any luck with this version? Can Figma team please validate and update documentation for Figma MCP Server setup?
Fabrício Sautner
Same problem here!
Kevin Lin
  • July 25, 2025
Same here!
varnika
  • July 30, 2025
Same here
Pascal Vendt
  • August 7, 2025
Same here
alexb2611
  • August 7, 2025
same here
Fabrício Sautner
Solved with update VS Code Version!!
danT
  • November 17, 2025
Issue seems back with VSCode 1.106.0  can no longer authenticate to Figma.
2025-11-17 10:44:12.169 [info] Stopping server figma
2025-11-17 10:44:12.190 [info] Starting server figma
2025-11-17 10:44:12.190 [info] Connection state: Starting
2025-11-17 10:44:12.190 [info] Starting server from LocalProcess extension host
2025-11-17 10:44:12.199 [info] Connection state: Running
2025-11-17 10:44:13.327 [info] Populated auth metadata
2025-11-17 10:44:13.328 [warning] Error getting token from server metadata: Canceled: Canceled
2025-11-17 10:44:13.331 [info] Connection state: Error 401 status sending message to https://mcp.figma.com/mcp: Unauthorized
