Prototype Navigate Links - Typing no longer works + Add Filter box
  • July 10, 2025
  • 9 views
john-mainboard
When you create a navigation frame link you see a list of the pages you can link to. Often you might have some template or alternative designs on the PAGE to keeps nice links for easy swap in/out, but unforunately you then get this:
  • Contact
  • Contact - Simple Version
  • Contact - Column Version
  • Contact - Alternative Simple
  • Contact - xxx
as you an see there could potentially be dozens of frames to link to all starting with Contact.
Start typing is gone?
Previously you could start typing, e.g. “CON” and then it will select the first match, however, I’m not sure when it happened but you can’t do that anymore, as soon as you type the charcters, those are now interpreted as commands, so you might might end up changing to drawing mode, or jumpin to the parent component becuase of the hotkeys you pressed.
Add a search/filter?
If we can’t have this type to filter behaviour back, please at least add a filter search box at the top of the page selection, so we can at least filter by CON - which will show all the contact pages above.
That will make it really easy to find pages in designs where the prototype is still under construction with multiple variations.
Alternative suggestion?
Maybe have the ability to drag the prototype arrow line to the LEFT pane where you can filter based on text. Drag the link to the frame in the LAYERS panel.
