Unpublished Library Showing in The Different Project
  • July 4, 2025
  • 19 views
Gaurav Thapaliya
We are using monthly professional plan on Figma and there is a team named "xyz" inside which I work on my design mostly. So inside this team there are several other projects as well which are our products as well. So, inside some of this project there is published design system made in the separate project within the same team so the same design system is used in couple of projects.
Now I have started to make another project which is completely new and I have not published any library there but when I am inside that new project and check the assets panel there appears the components of the design system used in other projects which I have not published in this file. How do I fix this? Please!  help
