export png image error, Text corruption and black lines
  • July 3, 2025
  • 4 replies
  • 204 views
newjinjang
How can I fix the problem where some parts of the image are corrupted when exporting the image to png?
Best answer by Zoltan Egri
@newjinjang
GPU driver update solved my problem! Try it!
Zoltan Egri
  • July 7, 2025
Same here!
When I export at 1x size or smaller, I see these kinds of errors on the exported image. However, if I export at a size larger than 1x, the error doesn't appear. The same issue occurs both from the browser and the app. Interestingly, when a coworker exports from the same file, they don't experience this problem.
Zoltan Egri
  • July 9, 2025
@newjinjang
  • July 9, 2025
Hi everyone! Yes, I can confirm that it is working by updating the graphics driver.
@newjinjang , gIad to see in the backend that you were able to fix the issue by following this solution! I've gone ahead and marked the topic as solved. Thank you!
newjinjang
  • July 9, 2025
I solved the problem by uploading GPU driver!Thank yo0000000u 😍 your my hero my soda pop
 감사합니다
