Dev Mode Not Visible Despite Full Seat
  • June 23, 2025
  • 170 views
mayur2423
Hello,
I have recently purchased a Full seat which includes Dev Mode access (screenshot attached). I’m using the Figma Desktop App, but I don’t see any option to enable Dev Mode under Preferences.
Here’s what I’ve already tried:
  • Confirmed I’m on a Full seat with Dev Mode included.
  • Using the latest Figma Desktop version.
  • Restarted the app and checked for updates.
  • Cleared cache and logged back in.
Could you please help me enable Dev Mode or check if there’s any issue with my account or rollout?
  • June 23, 2025
Hi ​@mayur2423, thanks for reaching out!
I took a look at your account associated with the email address for your Forum account, and I can confirm that you have a full seat. Normally, you can enter Dev Mode via the </> toggle on the toolbar or using the shortcut: Shift + D.
If successful, you’ll see a noticeable change in the Layers panel and Design panel into the Navigation panel and the Inspect panel.
To help pinpoint the issue, what are you seeing on your end? If you’re able to share a screenshot, that should help us figure out the issue.
BORA HONG
  • June 27, 2025
Writing a separate inquiry
  • June 27, 2025
Hi ​@BORA HONG, thanks for following up!
I took a look at your account associated with your forum email, and it looks like you do have an Organization Dev seat, but the Organization: NAVER has only granted you guest access. This means that your access is limited to the specific files, projects, or teams that NAVER invites you to.
If you don’t see the Dev Mode tools in a file,  you likely don’t have access to it. You’ll want to reach out to the file owner or an Admin to ensure you’re invited and can see the Dev Mode tools.
