problems copying indivisual code from the code block in dev mode
  • June 20, 2025
  • 5 replies
  • 83 views
Matthew Wood
In Dev mode if I want to just copy one or 2 lines from the style code block, it’ll paste it out as just a unicode instead.
I’ll have to use only the copy button to copy all the code for it to work - which is overkill and a waste of time for what I need. This never use to be the way.
  • June 23, 2025
Hi ​@Matthew Wood
Thanks for bringing this to our attention! I've been trying to replicate this issue on my end but haven't been able to reproduce it yet.
Would you be able to share a screen recording that shows what's happening? This would be really helpful for my investigation.
Also, have you noticed any pattern to when this occurs? For example, does it happen with specific file types, after certain actions, or in particular situations? Any details would help me reproduce the issue so I can properly report it to our internal team.
Thanks for your patience!
Toku
Matthew Wood
  • June 24, 2025
Hi ​@y_toku
yeah sure, i’ve created a Loom video
As for the file set up I wouldn’t know, it’s just handed over from the graphic designer. But it’s usually always set up the same way each time. We have other devs on the team reporting the same problem with other projects, so it’s not limited to just this one file.
We’re all using the figma in the browser, dev mode on mac/apple devices.
Thank you
Matthew Wood
  • July 24, 2025
Has there been any follow up? This issue is still happening.
MaximRoganov
  • September 17, 2025
Hi
I have the same problem. I use Linux + Firefox + browser version of Figma
Blake Pitts
  • September 19, 2025
I have the same problem as well. It appears to be a Firefox issue. If I use chrome I no longer have the issue.
