Issue: Figma make noindex meta tag
  • June 16, 2025
  • 9 replies
  • 292 views
PatrickD
I’ve created a project and connected a custom domain. In the file settings, I’ve made sure to uncheck the “Exclude from search engine results” option.
However, after publishing, the noindex meta tag still appears in the site’s head. There are no noindex tags in my code, and I’ve tried several workarounds; adding an index, follow meta tag and injecting a script to modify the DOM, but it seems Figma is inserting the tag automatically.
Has anyone encountered this issue or found a reliable workaround?
Best answer by djv
Hey ​@PatrickD, thanks for following up!
Our Make team recently pushed a fix. Please toggle the “exclude from search engine results” setting by clicking the checkbox twice. Then, republish your Make.
We changed how clicking the checkbox applies this setting to Make, so clicking the checkbox twice should bring you to your desired setting. You should then see the changes applied once your Make is re-published. Please note that it may take a few minutes for your changes to show up on the published Make, if you have already loaded the page recently, due to browser caching.
Please let us know if you run into any further issues.
  • June 17, 2025
Hi there,
Thank you for bringing this matter to our attention. I'm currently consulting with our internal team about your inquiry.
While I'm gathering information, would you be able to share your Sites URL? This would help us investigate your specific situation more effectively.
Thanks for your patience!
Toku
PatrickD
  • June 17, 2025
Hi there,
Toku
Thank you for the response, here is the site url: https://www.mygrowthsprout.com/
  • June 18, 2025
Thank you @PatrickD for providing the link.
To help us investigate this matter further, would you be able to share the site design file URL and grant Editor access to support-share@figma.com ?
Please be assured that sharing access with our support account will not affect your billing in any way.
Thanks!
Toku
PatrickD
  • June 18, 2025
Thanks!
Toku
Invite sent to support-share@figma.com with edit access. Design file url is: https://www.figma.com/make/pJ6ffnCHBxcN6DQlYj5ceB/Financial-Learning-App-Landing-Page?node-id=0-1&t=uwScclYvJ33AGQMK-1
  • June 18, 2025
Thank you so much ​@PatrickD ! I’ll share with our engineering team. I will keep you updated once if there is anything I can share with you.
Toku
PatrickD
  • July 10, 2025
Toku
Following up on this, are there any updates to be shared?
  • July 10, 2025
Léo Cosmic Shelter
Our Make team recently pushed a fix. Please toggle the “exclude from search engine results setting by clicking the checkbox twice. Then, republish your Make.
Hi Djv, I have the exact same issue, toggling twice the checkbox didn’t help, can you please advise how to solve this?
  • August 25, 2025
Hey ​@Léo Cosmic Shelter, thanks for letting us know!
This seems to still be behaving as aspected on our end since after the fix was pushed out.
Are you able to file a bug report here? https://help.figma.com/hc/en-us/requests/new
Our team would love to investigate what’s happening on your end.
