Missing Auto Layout settings section in the right panel (Desktop app)
  • June 13, 2025
  • 9 replies
  • 2268 views
Anastasia70
Hi,
The Auto Layout settings section has disappeared from the right-hand panel in the desktop version of the app.
I’ve thoroughly checked the entire panel, and the Auto Layout section is definitely missing.
I then opened the web version, and everything is there — the section appears as usual.
So technically, Auto Layout is working: the text inside behaves as expected, and I see the notification that Auto Layout was created. But the controls for it are missing from the right panel in the desktop version.
Could you please help?
Thanks in advance!
Best answer by Anastasia70
I figured it out — the Auto Layout section was hidden because I was in Draw mode in the desktop app.
Once I exited Draw mode, the panel returned to normal and I could see the Auto Layout settings again.
Lmao.
Anastasia70
  • June 13, 2025
As far as I understand, I somehow hid it in the desktop app, but I have no idea how to bring it back :(((
Anastasia70
  • June 13, 2025
Lmao.
  • June 13, 2025
Hey ​@Anastasia70 ,
Glad to hear you have found a fix! Yes, you need to come back to the Figma design tool in order to see the Auto layout section.
To go further, here is our guide to navigate in the Figma's new UI3.
I’ve gone ahead and mark as solved your topic. Thanks! 🙂
Wirkkarl
  • Active Member
  • June 15, 2025
Hi,
Thanks in advance!
Hi everyone,
I’ve noticed that the Auto Layout settings section is missing from the right-hand panel in the desktop version of Figma. I’ve checked carefully, but it’s definitely not there.
When I switch to the web version, the Auto Layout section appears as usual, and everything works fine—the text behaves as expected and I get notifications that Auto Layout is applied. But in the desktop app, the controls for Auto Layout just don’t show up.
Could anyone help me figure out why this is happening and how to fix it?
Thanks in advance!
  • June 16, 2025
Hey ​@Wirkkarl ,
This seems odd, I can see the auto-layout on desktop app. Could you please make sure you're in Design mode, and not in another mode like Draw or Dev Mode? Check the toolbar (see below) and ensure you’ve selected the asset with Auto Layout applied.
If possible, please share a screenshot of what you see in your end. It would be better for us to visualise the issue, thank you!
If you still can’t see it, please try clearing the cache on desktop app and make sure your desktop app is up to date. You can check our guide to the Figma desktop app for further information.
Let me know how it goes!
Clemence3
  • July 10, 2025
Thank’s I was starting to loose my mind !
Aniya
  • July 29, 2025
我遇到了同样的问题 绝对定位的功能也随之消失
  • July 30, 2025
Hey @Aniya, thanks for reaching out! If you’ve already tried the steps above and the issue continues, please try force-quitting and restarting Figma as well.
If that still doesn’t resolve it, feel free to contact our support team directly so they can take a closer look at your specific case: Submit a bug report. Thanks!
Dan S
  • October 7, 2025
Second time this has happened to me by mistake and I thought the app was bugged. Should really be more obvious you are in draw mode.
