Not able to access MCP server option
  • June 11, 2025
  • 3003 views
Hariom Pawar
No MCP Server option available here
The option to enable MCP server is not available, I have a professional acount and I used desktop app. Also I have latest version of figma desktop app. Please help
  • June 11, 2025
Hey ​@Hariom Pawar ! Thank you for your interest in Figma's Dev Mode MCP Server beta.
Just to confirm, make sure you meet all these requirements for using the MCP Server:
  • Have a Dev or Full seat on the Professional plan (which you should do)
  • Ensure that you have the latest desktop app downloaded and in use - Download the Figma desktop app here.
  • Then, make sure you've enabled the server so it is running locally on the Figma desktop app (steps here).
  • Lastly, make sure you've set up your client properly (we have instructions linked here for four main clients in our article: VS Code, Cursor, Windsurf, and Claude Code(Anthropic)).
For more detailed guidance, you can refer to our Guide to the Dev Mode MCP Server.
If you are still running into issues, please reach out directly to the support team, and mention the steps you have done. They can investigate it further in our backend: Submit a report. Hope this helps!
Boris Lopez-Guillemand
Hello,
I'm reaching out because I'm experiencing a similar issue.
I enabled MCP Dev Mode this week from the preferences panel and completed all the necessary configuration with Cursor.
However, over the past few days, I've been encountering connection issues
on Cursor's side, and I noticed that the MCP Dev Mode option has disappeared from my Figma settings (see screenshot).
Do you have any solution for this?
Euigeun Choi
  • June 20, 2025
@Boris Lopez-Guillemand
You opened other menu.
