How to Open the Generate AI beta Section in Figjam file Is there any Shortcut to open this tab?
  • June 5, 2025
  • 44 views
depaul
At the very first time I open the Figjam file, the Generate AI beta will Opened in default but I accidentally closed that tab, How can I open it again to use. Is there any short cut to open that tab.
  • June 5, 2025
Hi @depaul,
Thanks for reaching out about this issue! Let's try a few troubleshooting steps.
First, could you try using the keyboard shortcut to open the Actions menu?
  • For Mac: ⌘Command + /
  • For Windows: Ctrl + /
If you're using a non-standard keyboard layout, these shortcuts might be different. You can check your specific keyboard layout settings here: https://help.figma.com/hc/en-us/articles/5665442977431-Select-keyboard-layout
If that doesn't resolve the issue, could you share some screenshots of what you're seeing? This would help me understand what's happening in your FigJam file.
Looking forward to helping you get this sorted out!
Thanks!
Toku
