Not able to copy the gradient properties after the new update
  • May 29, 2025
  • 293 views
Sara Abid
After the new update I am unable to copy the gradient. Before I had to just select the shape/element which had the gradient I wanted, I would press ctrl+c and the gradient properties were copied and then I had to just paste it into the desired shape bt ctrl+v
But I am unable to do this now, is there a new way of doing this or Figma has gotten rid of this property?
  • May 30, 2025
Hi ​@Sara Abid
Thanks for reaching out about this. Just to clarify - are you looking to copy and paste only the gradient? If so, you can actually do this by copying and pasting just the fill property.
I've created a quick screen recording to demonstrate how this works:
Does this solution work for what you're trying to accomplish? If I've misunderstood your question or if this doesn't solve your issue, please let me know!
Happy to explore other options if needed.
Toku
  • May 30, 2025
Hi ​@Sara Abid
Toku
