Show/Hide UI keyboard shortcut in Figma/Figjam not working (Only Command +. does)
  • May 21, 2025
  • 60 views
Zach8
Command + /  has always worked but instead brings up a Search box.  Command + .  hides/shows UI.    Why is this and if a common change why do the dropdown menus still list the ‘Command + /’ quick key?
Also the haven’t used any new apps (Notion, Spotify and Logic Pro are the main ones)
It’s super frustrating when this behavior occurs and want to know if this is something I’ve done or Figma just being slow to update documentation.
Zach8
  • May 23, 2025
Also when I click  Help> Keyboard Shortcuts a bottom section appears but it just blank/black (instead of usually showing the Shortcuts.
I have the newest version of the desktop app.  I am also running Notion and Spotify.
Zach8
  • May 23, 2025
Someone helped me out via Reddit and it was my mistake.  I can’t see how to update/cancel or modify the above post to close the issue.
