How to hide horizontal scrollbar in Figma Sites?
  • May 18, 2025
  • 6 replies
  • 342 views
Dhwani Shah
Hello Everyone!
I’m using Figma Sites for my design portfolio and added horizontal scrolling to a frame. It works, but when I preview the site, a horizontal scrollbar shows up, and I want to hide it for a cleaner look.
Here’s what I tried:
  • Set the frame to horizontal scroll under overflow behavior
  • Tried to look for an “On Drag” interaction to make it feel swipeable — but it’s not available
  • Thought of using arrows + variants, but that’s a lot of work and not ideal
Is there any way to hide the scrollbar in Figma Sites? Or any better workaround?
Thanks!
matheopw
  • July 21, 2025
I have the same problem.
Reneé Cagnina Haynes
Same here.
matheopw
  • July 30, 2025
I changed the horizontal scrolling with a bottom option. I created a component with its variants and added interactions between them. So, when someone clics the bottom, it changes to the next variant. It works well and I believe it’s better. Hope this helps you.
Don’t doubt to reach out if you need help.
Timon Jorn
  • September 9, 2025
I’m running into the same issue! I was able to remove the scrollbar by pressing the ‘interactive’ tab and then: ‘Make interactive with code’, then ask it to hide the scrollbar but keep the functionality. It works, but unfortunately the blocks became “code designed”? So unless I remove the code first I am not able to readjust the design of the blocks in anyway anymore.
If you are fully finished with your design and you only need to remove the bar it’s a good workaround, otherwise let’s hope for a better solution soon :)
Maxime_De_Greve
Same problem here :-(
a.rachman96
  • November 25, 2025
I got the same issue here. Last night I have designed my web using Figma app, and nothing has happend, everything worked well (no scrollbar appeared), but this morning IT SHOWS UP when preview. Another, my layout is also messed up!
Is anyone found the solution? I have looked around on the internet and didn’t find any answer.
