Cannot change visibility or assign boolean to
  • May 17, 2025
  • 52 views
SKL
Hello,
I’ve got a component set that I want to assign a boolean to, for the visibility of the word “Owner.” I successfully assigned it for every variant except the one called “Open.”
The options to hide the layer and to apply variable/property are grayed out, only for this text layer. It also prevented me from assigning the boolean for the entire component set.
I can still change the visibility of the layer from the left panel.
I found a workaround by pasting “Owner” from a different variant, but can anyone explain why this is happening?
Here is the figma link: https://www.figma.com/design/cMcWnX5NQECJ5vcNzWoKRk/test?node-id=1-101&t=0VnqJiQ7GCU6ANYi-1
