Gif not working in published figma sites
  • May 8, 2025
  • 4 replies
  • 412 views
BEN_GEORGE1
When u add gif in figma site it loads in preview but when you publish its not loading
Best answer by Celine_
Hi everyone! I checked with our engineering team, and it turns out this issue can occur when a GIF exceeds the size limit.
Figma supports GIFs up to 50 megapixels, calculated as: (width × height × number of frames) / 1,000,000 ≤ 50
If your GIF is over that limit, try reducing its size and uploading again. Hope this helps!
Braxton Mastre
I am also having the same issue. The webpage refuses to load them.
  • May 20, 2025
skylarina
  • May 21, 2025
we need to bump that number up. a 1280x720 gif (for say our Hero bg) puts us at 921,000 before calculating any frames.
So either we need to bump that number up or add an autoplay+loop for .mp4 files
Samuel Shen
  • August 21, 2025
This supported size is ridiculously small, this basically makes any gif unusable in Figma Sites (unless it’s like a 2 seconds quick flicker, anything beyond that is bigger than what Figma supports)
For a product as big as Figma, this is unacceptable.
