Nested Component purple outline bug / workaround (?)
  • April 28, 2025
  • 131 views
Jeskosen
Reposting this because the topic was closed without solution. Just ran into this problem. I have a nested swappable component and after swapping the component the swapped component had a purple outline as though it would be selected which it wasn’t.
When I duplicated the Instance the outline was gone in the duplicate. So I deleted the ‘faulty’ instance and all was good. So that could be a workaround. Hope it helps someone.
Happy designing and bugchasing to everyone! 😉
  • Figmate
  • May 2, 2025
Hi ​@Jeskosen, thanks for letting us know about this!
So sorry you're running into this issue. It looks like you and some other folks in that thread have bumped into a long-standing bug that we're keeping an eye on. Unfortunately, we can't give you a definite timeline for when it'll be fixed, but we really appreciate you bringing it up.
To help out in any small way I can,  I've added your post (and that other one you found) to our internal report. Fingers crossed it gets a bit more attention and maybe moves up the list!
Also, a big thanks for sharing your workaround – that's seriously helpful for others!
Thanks again for your help with this.
Seth_Shaw
  • May 20, 2025
Edited, found a workaround
Jeskosen
  • May 21, 2025
did you use my proposed workaround or a did you find a new one? If so please let the people know how you did it. :)
