Components disappear in prototype after changing animation delay or duration
  • April 5, 2025
  • 81 views
Karina Catalán
I'm experiencing an issue in Presentation mode. When I adjust the delay or duration of an animation, the components involved completely disappear in the prototype view.
This is happening across all my files on figma.
I've tried different browsers, the desktop app, and changing animation types — the issue only appears when I modify these timing values (delay/duration).
Any ideas or workarounds? It’s kind of annoying cuz makes the works takes longer.
Dali Logbo
  • May 5, 2025
When I modify my mockup, the components that are visible in the mockup disappear in the prototype. Is this a bug?
Dali Logbo
  • May 5, 2025
I have the same problem since this morning, mu modify components on the mockup disapear on the prototype
ksn
  • May 21, 2025
Hey both - sorry it’s taken a while to get in touch. First, based on each of your mentions, I think that there needs to be more visibility in how each of your prototypes are structured.
Wanted to ask you two if you could first do the following.
  1. Share edit access to the files you’re working on that include these with support-share@figma.com -- you will not be charged for this. This is really helpful, as it helps us try to replicate on our side (and then file bug tickets).
  2. Send me the title of the filed you shared. You can reply here, or PM me with it.
If you can’t share the files, it’s no problem. Please drop that info when you have a moment.
Thanks!!
