I can't publish my library
  • March 18, 2025
  • 10 replies
  • 129 views
Gra
Hi! I was able to publish my library without any issues this morning, but now I'm getting the error message: "Publishing failed: Please reload the page to publish."
I've tried reloading the page, quitting Figma, restarting my laptop, and confirming my network connection, but nothing seems to work. I've been using this file for over a year and have never encountered this issue before.
glybin
  • March 18, 2025
You’re not the only one. Seems it’s a problem on Figma’s end.
Luiz_Eduardo_Andreolla
Same here, I almost had a meltdown thinking I had ruined my project. Thank goodness I'm not the only one!
Gra
  • March 18, 2025
I finally published my library! Were you able to publish yours?
Gra
  • March 18, 2025
Same! 😭 I finally published it, were you able to publish yours?
SteffMueller
  • March 18, 2025
I got the same error today and came here to find a solution.
So it might be a bigger issue then, although figma status does not recognize yet
https://status.figma.com/
  • Figmate
  • March 19, 2025
Hello, thanks for the heads-up and for your patience!
The engineers have released a fix for this. Please refresh Figma to ensure you're using the latest version. We apologize for any inconvenience this issue may have caused. If you're still experiencing problems, please let us know.
We appreciate you flagging this; it helps us improve our product!
Thank you.
Yes!! seems like it was fixed yesterday 🙌🏻
glybin
  • March 19, 2025
Everything seems to back to normal.
David_Brien_Swann
Except now i’m getting the same error. Tried everything I can think of. Even went into the history panel, restored earlier versions that previously were published, then tried publishing those. Still get the error!
David_Brien_Swann
Also deleted all new component and tried publishing. No luck.
