Can no longer duplicate my file
  • October 7, 2024
  • 6 replies
  • 1111 views
j.willetts
Hi guys,
For some reason I can no longer duplicate one of my files in Figma.
This initially happened when I created a new branch within the file; so I assumed you can’t duplicate a file whilst it has a branch open.
I closed the branch and was able to duplicate the file again. For some reason it recently stopped letting me duplicate it again and I can’t figure out why.
We used this file as a starting point for many projects so it’s essential that we can duplicate it.
Thanks!
Gayani_S
  • October 7, 2024
Hey @j.willetts, thank you for reaching out!
One reason why you’re not seeing the “Duplicate” option on a file with branches could be that you’re looking at a branch of that file. The option to duplicate is available on the main file. When you have files with branches please check and see if you’re on the main file, not the branch, and see if you can duplicate the file.
You’ve mentioned your file does not have branches anymore and and you’re not able to duplicate it. Are you seeing this issue in the browser and the desktop app?
Can you please try the following workaround?
You can also duplicate a file by adding /duplicate to the end of the file. This only works when you are viewing the full file URL.
If you have a specific frame or layer selected, Figma will add an ID for that node to the URL. For example: ?node-id=21%3A0. You need to remove any node id’s before adding /duplicate to the file’s URL.
Please let me know if you’re able to duplicate it with the workaround. Happy to help further!
j.willetts
  • October 7, 2024
Hey @Gayani_S thanks for the reply.
as you can see there are definetely no active branches for the file.
I’m not able to duplicate it on the app or on the browser. Your workaround did work however, but I’d rather not have my team need to rely on something like that.
Any other ideas?
James
Gayani_S
  • October 15, 2024
Hey @j.willetts, apologies for the delayed response and thanks for conforming this!
I’m actually not sure why you’re not able to duplicate the file on the normal method. I’ve just created a support ticket on your behalf, so our team can take a look on what’s causing this. Your ticket number is #1150382, for reference.
Our support team usually takes up to 24 hours to reply back to emails - tends to be quicker than that in normal circumstances. However, please be aware that we are facing increased contact volume so there might be a delay.
Appreciate your patience in the meantime!
Bruno_Garcia1
  • November 26, 2024
Hi 👋
I was having the same problem, I wasn’t able to duplicate some files (the duplicate option didn’t appear in the dropdown) but I was able to duplicate the files using this workaround. It would be good to have this fixed, but I’m grateful that I was able to have this workaround at least as a temporary fix for this problem.
Gregory-Danlake_Patricia
I’m having the same issue, but the workaround is not working for me. Has there been any progress made with this issue over the last couple of months? Thanks.
GMartin
  • December 11, 2024
Copy link on the file, paste that link in a browser (where you’re already logged in Figma)
add /duplicate at the end of the path while removing any parameter, it’s going to automatically duplicate the file.
