Error: Two rectangles with same property but look different
  • March 7, 2023
  • 5 replies
  • 361 views
Haowei
It seems that I have created two rectangles with exactly the same style property, but they look different. Even copying & pasting the style can’t solve this problem.
tank666
  • March 7, 2023
Make sure there isn’t another rectangle below the right rectangle.
Haowei
  • March 7, 2023
Sure, only 2 rectangles in the frame.
Stephane_Popout
This is incredible😂
Can you log the rectangle fills from the plugin console ? Are they really the same ?
What happens if you change the color and set it back ? Or if you duplicate one of them ?
steventraaan
  • March 7, 2023
Are both of the inspected css styles the same for both of the rectangles?
It’s interesting because the rectangle on the right looks exactly like if you had 2 rectangles with 40% opacity stacked right on top of each other.
Haowei
  • March 8, 2023
I’m not sure what happened to my poor rectangles, but they do look same in Inspect Mode.
