Interactive component doesn't respect multiple drags
  • May 20, 2021
  • 7 replies
  • 1779 views
Shunsuke
When I create a slideshow with frames it goes to left and right thanks to smart animate.
But interactive component ignores the second drag interaction.
Demo
Pawel4
  • July 1, 2022
I have encountered the exact same problem. I think there is a solution to that with usage of mask. I’ll get back to you with a solution if I’ll be able to resolve that.
Still though, it would nice and very intuitive to have it work as presented.
Sage_Abplanalp
Did you ever find a solution to this? I’m having a similar issue with it not respecting the ability to drag backwards and getting me stuck between two slides like that.
tank666
  • November 2, 2022
Hey all! Since it is very difficult to determine the cause and guess anything without having access to the file, I suggest you look at the official example of such an interactive component here:
Figma
Sage_Abplanalp
Thank you! I was actually able to figure it out after a lot of trial and error. It appears I needed to apply the drag to the slide directly and not just that whole variant.
Peter_Steven
  • November 16, 2022
Hey did you make it work? I was actually giving it a try with the masks but still fails.
Beside the fact that it starts dragging everywhere 😕
Rhys6
  • June 25, 2024
Hey @Sage_Abplanalp. I am still running into this issue. I have added the drag directly the content panel (think of the variant containing a tab bar and content) not the whole variant frame but it still doesn’t work and defaults to the first drag in the list. Any ideas? Thanks.
Sage_Abplanalp
@Rhys6 Are you making sure to apply the drag to the slide content itself? If it’s part of the variant frame not the content itself it can still get stuck.
