Instance override scaling corner radius
  • September 12, 2024
  • 160 views
Wolf_Boese
using the K shortcut to scale will impact corner radiuses within a component at the same rate as the dimensions. (as expected)
This can be done to nested components where initially it works as expected.
when overriding the nested component instance to another that also contains rounded corners the “scaled” attribute seems to get lost and the rounded corners default back to their unscaled values.
