When applying text styles that have associated variables attached the values presented do not respect the applied mode. For instance I have a title that has a mode for Mobile (20px), and a mode for TV (40px), when i open up the style, the default mode (in this case mobile) is displayed instead of the TV mode size.
I have also observed this within grid layouts when applied it shows the default mode (26 columns). When in reality it is actually 24 columns, if you then detach the style it shows the correct number.
And when detached you can see it shows the correct value
Seems this was a major oversight, as it makes applying size variables pretty time consuming, as I have to check if I’ve chosen the correct size by clicking and opening up the variable list.
In short it seems to default to the first default mode, instead of respecting the chosen mode. It also only seems to affect styles.
Anyone else found this to be an issue?
Yes!! Having the same issue and came here to see if others were experiencing it. The only workaround we’ve found so far is to just add a description to the text styles with the other mode values, but it’s definitely not great.
Ahhh thank you, I didn’t think about using the description!
I’ll use this as a workaround for now but it’s definitely frustrating that the values do not ripple down correctly when the mode has been selected. It makes it extremely difficult for those consuming the system to really use it correctly.
Hoping to bump this thread as it’s quite frustrating and feels like a pretty big oversight.
Hey All, so sorry for the trouble and delayed reply!
This is already on our team’s radar for improvement. Right now, this is expected behavior. The styles picker does not reflect modes for typography variables. The team plans to implement changes to make this less confusing.
As a temporary solution, as suggested by Paul, you can add a description to the text styles with the other mode values
Hello,
when creating font variables with modes (e.g. device mode for desktop, tablet and mobile) and applying those variables to font styles, the preview of the font size is wrong. It always shows the size defined in the default mode. However the used size in the frame is correct, but it is super distracting that Figma shows the wrong font size …
Anyone experiencing the same issue? Is this a know bug?
The attached file shows example for multi dimensional modes or single modes. The issue happens in both cases (our initial assumption was the multi dimensional modes).
Figma shows wrong font variable preview.fig (563.4 KB)
Cheers & Thx
Harald
Hello,
i found an old post from June that addresses the same problem.
In the meantime I found out this problem is not just related to font styles. It is a problem in all styles (e.g. effects). The preview always shows the default variable mode value, but never the actually used one.
Hello,
are there any updates on this? We are facing the same issue.
It is super misleading if the wrong values are shown to designers using a design system.
See also
https://forum.figma.com/t/font-style-using-variables-with-modes-shows-wrong-value-in-style-preview/87107/4
BR & Thx
Harald
Hey Harald, I haven’t heard anything back yet but it still persistent in the older version of Figma (I haven’t got the new UI yet). I’ve been using the above method and including the values in the description to at least tide us over until there is a fix. I am hoping that it won’t be too much longer though.
Hello,
it’s definitely NOT solved in the new UI.
Harald
Hello.
We also had feedback from our design system community about this bug. It’s super irritating when you work with different devices or densities.
Please fix it soon!
Thanks
Hey team, when can we expect a solution to this? This is super important as I’m working on a bi-lingual interface and this is super important.
Hey, running trough the same issue at the moment. Is there any update on this? cc @dvaliao
Hey!
Any news regarding this issue? It is already 6 mnths passed but the problem still exists.
Is there any workaround at this moment from Figma team?
The issue still remains very much unsolved.
It’s been 8 months since it has been on the “team’s radar”. Seeing how variables and styles are an integral part of software, I’m really hoping to hear an update on this soon.
Cheers.
I am wondering how Figma can say variables are out of beta (aka production ready), but at the same time important things are missing:
  • Wrong variable preview
  • No library swapping support
Why is the ticket marked as “solved”?
Sorry for the confusion, ​@hummh
My reply was marked as the best answer since it’s the only one so far with direct buy in from our Typography team.
While I wish I had an actual update to share, this is not high priority on the team’s current pipeline. It is on the team’s radar to improve in the future, but there is no specific timeline we can share on when/if variable preview will be rebuilt to include modes for typography variables or library swapping support.
That’s what is wrong with Figma, while customers are paying a lot of money Figma focusses on all the wrong items it seems.  All of these things are base functionalities for design systems and instead of putting focus on a new UI, Figma should focus on those base functionalities again.  For example we have designers in our company which use our central design system but they keep seeing the values from the default mode instead of the selected one.  One of the reasons why designers need to invest time in plugins like tokens studio because Figma seems to forget what Figma was built for!!! Nowadays we need so much workarounds in Figma, design systems should be their core focus!  We don’t care how styles and variables where built and that it’s difficult to fix, just make base functionality work!
So ​@dvaliao how do we bring more attention to this issue? We’re using variable modes (driven by Token Studio) to create type styles (in addition to the modes setting spacing, border radius, etc), and having to explain to designers that what they see in the style menu in the right sidebar is not accurate seems to be a pretty big miss. If that’s also going to be true about spacing, border radius, padding, etc then the frustrations with the broader design team are only going to compound.
Clearly there are a lot of folks frustrated by this; how do we help elevate this priority?
@dvaliao My enterprise design system team is having this same issue and it has quickly become a blocker. Our executive reviews require accurate type and our engineers require accurate token references. We are having to detach type and manually override to display the correct styles even though the values are accurate.
This is a high-priority item for our team! How can we get this prioritized?
Hey All, thanks for your continued feedback!
I’ve flagged this topic again to the team to advocate for its prioritization in the their future pipeline.
Hi everyone, I have the same issue, are there any updates on this so far?
Hey ​@Dmitrii Danilevich, thanks for following up! The team is aware of the issue and it’s on their radar to improve in the future, but unfortunately, it’s not something we’re able to prioritize at the moment. We’ll make sure to share any updates on this post.
@Gayani_S Please convey to your leadership the depth of our frustration. This is a significant failure on Figma’s part to support their own functionality. This bug makes it impossible for designers or engineers to see accurate type style information when using variable modes to theme. This is your own core functionality and is costing every organization that tries to use it valuable time in working around it. It’s now been over a year since it was reported and it’s incredibly frustrating for the response to be ‘we just can’t get to it right now’
Hi ​@Jason Pamental - stepping in for Gayani on this one. I know that my reply will likely be disappointing to hear, but we don’t have any updates on our end that we can provide at the moment.
We try our best to make sure every Figma user is able to work on their designs with as less friction as possible. Speaking for myself, I don’t want to make any promises on timeline or how this will be addressed.
However: what I can do is forward your recent comments as you requested, as I do want to advocate for you (and everyone else on this topic). I’ve gone ahead and done so, and your feedback has been acknowledged.
Apologies that I can’t provide more info.
Colors have the same issue. Can’t believe this is still an issue 3 years after variables rolled out. When In the beginning we were directed to feed them to designers through styles. There’s also no way to cleanly implement composite typography tokens in Figma. We can’t expect designers to have to apply every property variable just to use some typography.
This needs to be addressed ASAP. Variables needs some love, it’s been half-baked for 3 years.
