Manipulate Elevation of a Layer / Drop Down Menu Case
  • August 30, 2024
  • 52 views
Renan_Malato
When you have a form with Drop Down menu / Autocomplete fields with autolayout, the layers list order determines the position of a layer in your form, not the elevation
So when you click to dropdown the field, the dropdown goes - in the back of the below layer
The way I find to hack that is creating kind of a Position Absolute Wrapper for each line and then reorganize the layers to make that appear on front
This is so weird and tricky and takes a lot of time everytime I have to do this.
I believe a simple Elevation zIndex Control when is set to autolayout would solve that for us
Please, Figma!
The way Figma now arrange layers layout is - what is below is above
Eldurini
  • August 31, 2024
Hi @Renan_Malato
Glad you solved it this way, because the only way to solve it is like what you mentioned above (at least as I know till this moment).
I hope Figma considers this suggestion. Try sending it to them by email ✅
