Different border radius wont work
  • September 17, 2024
  • 9 replies
  • 139 views
rwb_marns
Different border radius value wont work. It will work if and only if it has the same value.
Best answer by Raphael_M
There is a small curve
  • September 19, 2024
Hi there,
Thanks for reaching out. I wanted to check for any unexpected behavior, and it seems to be working properly on my end:
To replicate the issue, could you share the detailed steps you took? Additionally, a video recording would be helpful. I hope to investigate this further!
Toku
rwb_marns
Hi y_toki,
Glad you responded to my post.
Sadly, I can’t make a recording as of the moment since I was not on my laptop right now. But I can give the steps how to replicate the issue I encountered.
Step 1: Create a shape, Rectangle will do.
Step 2: Put a corner radius using this field.
Step 3: Once done, then click this to customize each corner radius.
In that case, you can now notice the issue.
Looking forward for this to be solved. Thank you!
  • September 24, 2024
Thanks for getting back to me with the details. I tried to follow your steps—could you check if I did it correctly?
It seems to be working fine for me, but please let me know if I’m misunderstanding anything.
Toku
rwb_marns
  • September 25, 2024
Yes, you did it right. Right now, as I tried back again to replicate the issue, it seems working now on my end. Is this could possibly be an intermittent issue?
Thanks for checking! It might have been a temporary issue, so I looked into it internally. We couldn’t confirm if it was a bug on our end. It was probably just a network or cache issue or something else. I’m glad to hear things are back to normal now.
Please let us know if you see this issue again! We will definitely investigate more.
Toku
Raphael_M
It’ll just look like it doesn’t have a border radius because of the humongous radius value you used.
I’m not sure why each time you increase the radius value, the radius of the adjacent corners are changing visually.
rwb_marns
Can you try the exact value I used based on my original post?
Raphael_M
  • September 26, 2024
rwb_marns
Yeah, I think it is because of the variable I used in other corners which is 9999. Got it now.
Thank you!
