Green lines overlaying across different projects since using UI3
  • July 20, 2024
  • 6 replies
  • 887 views
Emilia_Tonello
Hiii 👋 first-time poster here!
I’m experiencing green lines resembling wireframes or bounding boxes across different projects since I started using UI3. These lines overlay the design elements and do not disappear, persisting across various views. It seems to be a graphical bug, and I’m unsure how to make them disappear.
Gayani_S
  • July 22, 2024
Hey @Emilia_Tonello, thank you for reaching out!
This looks odd 🤔, I can reach out to the teams internally. But before that could you please check for me if you’ve toggled the outline mode on?
Also are you seeing this on a specific file or all your files?
You can use the keyboard shortcut to disable show outlines:
  • Mac: ⌘ Command ⇧ Shift O
  • Windows: Control ⇧ Shift O
Thanks in advance!
Emilia_Tonello
Hi @Gayani_S! thanks for your reply.
This is happening across mutiple files both in my personal and enterprise Figma accounts. All the outlines seems to be objects within masks outlined in green. I don’t have the outline mode on (I was thinking it was this, but nope). And this started since I’m using the latest Figma version, I went back to the previous UI but still won’t work 😕
Screenshot 2024-07-22 at 18.02.39
Gayani_S
  • July 23, 2024
Thank you for confirming this @Emilia_Tonello! Can you let me know if this is happening in the desktop app, the browser or both?
I’ve reached out to the team internally. Will get back to you asap.
Appreciate your patience in the meantime!
  • July 23, 2024
These are mask outlines. You can disable them in the settings.
Emilia_Tonello
Yay! what @Gleb shared worked 👏 tysm both! @Gayani_S
Gayani_S
  • July 24, 2024
Thanks Gleb! And sorry @Emilia_Tonello for the late reply, I also got the confirmation from the team to disable the mask outlines.
