About Figma slot function。I very much hope to have such a feature.
  • May 21, 2025
  • 206 views
Panwei
Enhancing Component Flexibility with Slots: A Real-World Scenario
"We often find ourselves needing to edit content within a component instance without detaching it. While a 'change once, update everywhere' approach for simple variant states is great, we really need more flexibility within those instances."
Understanding the Power of Slots
The Slot feature introduces a powerful new component property acting as a designated placeholder within a master component. This allows components to achieve both rigorous standardization and dynamic flexibility. Designers can now freely swap, add, or remove content and structural elements inside a component instance, all without ever having to detach it.
When combined with Auto Layout and other Component Properties, Slots make components significantly easier to manage and far cheaper to maintain. This approach is particularly effective for use cases involving diverse content, frequent content updates, and high reusability, like those found in enterprise (B2B) products or when adapting designs across multiple platforms.
  • When crafting a component, you simply define and place a Slot placeholder within its structure.
  • When using an instance of that component, you gain the ability to insert virtually any design content into the designated Slot area.
This methodology can revolutionize core design scenarios, including overlays (modals), lists, tables, navigation elements, and complex layouts.
Tackling Component Management Challenges
Are teams struggling with overly complex component library structures? Are components too rigid, leading to a proliferation of unmanageable variants?
By leveraging Slots, components become dramatically more flexible and efficient. This enables us to truly deliver on the promise of "complex setups, simplified usage," empowering designers to build intricate interfaces with unprecedented ease.
