Formulas in token values + Transparency support for color tokens things
  • April 15, 2025
  • 34 views
xxver
1. Formulas in token values (mathematical operations)
   It would be incredibly useful if we could use simple formulas (e.g. paddingXS*2 + paddingXL*2) when determining token values. Many design systems (for example, Ant Design) use this approach to dynamically obtain tokens. Currently, we haven't even found an analog that can be implemented without any plug-ins). The lack of such a feature makes the work a little more difficult.
2. Transparency support for color tokens
   Currently, if we need a semi-transparent version of a color marker (for example, purple is 100 at 50% opacity), we have to create a separate marker or manually redefine opacity, which breaks consistency. It would be great if we could keep the original color marker and just apply an opacity modifier (for example, "purple-100" at 40%) without resetting the base value.
Thank you for reviewing these improvements — we are glad to see how Figma is developing!
