New UI - Scale Properties - Tab Order
  • January 28, 2025
  • 19 views
naeim
I use the Scale options a lot and 9 out of 10 times I know exactly what size in width or height I want to scale to. I also use Tabs a lot to navigate through options whenever possible.
In the new UI when I click K and open the Scale options the first focus is on the 1x multiplayer and the Tab goes through the alignment box, it takes 20 tabs to go from the multiplayer 1x option to the Width input.
In the old UI, I click K to open the Scale properties, press Tab once and enter my Width…
I believe that most users will agree that the Width and Height inputs should come next after 1x in the tab order. (I am not even sure what that alignment box is supposed to do exactly , I have never used it.)
Be the first to reply!
