Tip for creating tap targets larger than the actual component
  • February 13, 2025
  • 5 replies
  • 311 views
Sofie_Katan1
In the past when building components, the hover and tap targets where always the same size as the component itself.
For example, in a list where the hover or tap area should span the full width of the page, the component itself needed to be full-width.
So to improve the life of our developers we wanted to transitions from using components with built in margin to allow setting the margin externally.
However, the challenge was how to ensure the component would still have a hover/tap target that spanned the full width.
I couldn’t find any suggestions online, but after a lot of fiddling and hacking, I discovered a surprisingly simple solution.
I wanted to share it here in case others have faced similar challenges:
Solution
Step 1:
Create a layout using auto layout so that the component can scale as needed based on the content. Add the state as it’s own layer and set the position to absolute.
For each variant you can change the state as you would normally change the background.
Step 2:
Set the layer to the correct size of the target and center it. Now go to the positions panel and select all directions while holding down shift.
This way the horizontal constraints will be fixed and the padding will stay consistent. In this case 16px horizontally and 8px vertically. Note that selecting scale in the dropdown will not work in this case as it would result in inconsistent padding for the target when it scales.
BTW the method also works super well for inline buttons and icon buttons where you might want to have the hight 24x24 for better alignment, but have the tap target 48x48 for accessibility. OBS!! Just be careful when using these components in prototypes as you need to ensure the connection is set from the state and not the main component!
What do you think? Found better ways of achieving the same result?
StanleyJames
  • February 15, 2025
This is such a smart approach, Sofie! Making tap targets larger without altering the component’s structure is a game-changer for usability. I’d love to hear more—what was the simple solution you landed on? Did you use pseudo-elements, invisible overlays, or some CSS magic? Always excited to learn new tricks that make development smoother!
Chris_019283
I know about this trick. My question would be how do you deal with this on the front-end? Can you do the same thing without doing css hacking?
The Twin Peaks Menu
We wanted full-width hover/tap targets without forcing components to be full-width.
By using absolute-positioned state layers inside auto layout, we preserved padding and flexibility.
It even works for icon buttons with small visual size but larger tap targets for accessibility.
This is a smart and elegant workaround—using absolute positioning within auto layout keeps things scalable and dev-friendly. We've used a similar method with invisible background layers, but your approach is more structured. Thanks for sharing!
Sofie_Katan1
  • July 10, 2025
@Chris_019283 in CSS you have negative margin/padding which our developers use in these cases. Basically our figma way of doing it makes up for that feature missing in figma. If they would add native negative margin/padding as you have in CSS we wouldn’t need the workaround..
jonesnatelye
  • August 21, 2025
@Geometry Dash in CSS you have negative margin/padding which our developers use in these cases. Basically our figma way of doing it makes up for that feature missing in figma. If they would add native negative margin/padding as you have in CSS we wouldn’t need the workaround..
wow like it!
