I create a plugin that can convert image to base64
  • April 30, 2023
  • 4 replies
  • 2105 views
jk2K
refer to
  1. How about having an option copy as base64?
  2. Export to base64
@user19 @Anwarul_Islam
I created a plugin that can convert image to base64
tutorial:
  1. run plugin https://www.figma.com/community/plugin/1226170501704996152/Pwireframe
  2. select image
  3. click Copy as Base64 button
this is demo
todo
automatically write base64 text to clipboard (require Figma to provide an API for writing to the clipboard)
Stephane_Popout
Nice job! Would be useful to many
davy_zhang
  • August 24, 2023
I’ve encountered an issue with the current plugin that’s preventing it from successfully converting images to base64. Typically, I rely on the tool available at Image Base64 for this task. However, it would be much more convenient if I could perform this conversion directly within Figma, eliminating the need to upload images separately. Unfortunately, it appears that the plugin is currently experiencing difficulties.
jk2K
  • August 26, 2023
image larger than 1MB experience memory issue, I will try to fix it
jk2K
  • August 26, 2023
fixed,
root cause: Figma text node not support large text
automatically copied to the clipboard when use in Figma desktop
you need to copy it manually when use in Figma browser,
