Fully support large images
  • April 29, 2024
  • 768 views
Lane-C
When I paste large images into Figma, they end up a fraction of the original width/height and really blurry. In the many cases where there’s text, it can hardly be read.
This issue is due to a limitation by Figma to reduce the longest edge of an image to less than 4096 pixels as outlined in the Support Note here. On retina Macs, images are reduced to less than 2048 pixels if image resolution is set at 2x, which is incredibly common.
Often, I’m dropping in screenshots of existing webpages, so that I can design alongside them or have them as a comparison reference for stakeholders. Other times I design with code and want to bring over the screenshots for my product manager to create the copy or make edits with comments. Sometimes Figma is a place to bring together new ideas and functions like an artboard. But in all these cases, and many more, I run into this limitation causing great pixelation.
I understand Figma’s aim for us to design within their application but it should fully support other massively popular design mediums like large images.
Benji_Greig1
  • December 16, 2024
In the meantime you can use this plugin to circumnavigate the problem: https://www.figma.com/community/plugin/799646392992487942/insert-big-image
