Transition on visibility
  • July 27, 2023
  • 511 views
Randall_Tyner
Now that I can set visibility with a variable, I would like to have the ability to defined a transition for the visibility of that item. Then I could flip a variable to turn on or off a UI element and have that element transition onto the screen. (slide in, slide out, fade in or fade out).
Without this feature, I have do some crazy work arounds and given the limitation of variable interactions on a nested component… it is a pain in the… workflow.
  • August 11, 2023
Thanks for the idea, @Randall_Tyner!
We’ll pass this onto the team for consideration. Don’t forget to also Vote up top, so we can gauge interest from the community. 🗳️
Christian_Brandt
This would be so great!
Lucas_Orellanos
This would be really helpful!. I’ve been looking for this option since variables came out. I use local variables a lot to show or hide elements in the UI, and having the ability to animate these transitions would make the final prototype even more realistic and feel polished.
