Slides: Can you add animations to groups and objects within slides?
  • July 18, 2024
  • 14 replies
  • 1571 views
Curtis_Giberson
From what I can see animate only works from slide to slide as a transition. But there’s limited animate options and I would like to stagger or animate individual areas of slides. Is that possible? If I had say 4 blocks of objects/text/pictures or something it would be nice to animate each individually after the other to bring my slide content more to life.
Also, it would be nice in Grid View if you could select a slide and drag to add similar animations right there.
Auto animate after delay doesn’t seem to be available either. Given limited animation features I’m adding some duplicate slides and using smart animate between them but I have to click or use spacebar to trigger each slide. Wish you could choose animate, type of animation and after delay or normal slide click progression.
Louis_Trouillier
+1 Need this as well. PowerPoint does have this, so why won’t we implement this minimum feature in Figma slides?
  • August 21, 2024
Hey All, thanks for the feedback!
We’ll pass this onto the Slides team for future consideration.
Alex_de_Lacey
The slides product is very promising, but this is a key missing feature!
themaster6466
Some tools only offer limited animation options, so you can’t stagger or individually animate objects like you want. While duplicating slides and using smart animate is a clever workaround, having to click or use the spacebar to trigger each slide can feel a bit clunky. It would definitely be nice if you could set animations to trigger automatically with a delay or manage them easily from a grid view.
Hong_Phi_Tran
Yes please, this is much needed for designers who needs to pass on presentations to their marketing counterparts who aren’t as familiar with Figma controls. The animation triggers need to feel seamless and easy to manage! TY!
Weirdo
  • Active Member
  • December 10, 2024
Literally Figma Design is better for presentations than Figma Slides.
hilde_ramsdal
This is such a key feature in my opinion—when presenting, you don’t want to reveal everything all at once. It can come across as overwhelming for the audience and isn’t the best design approach. Honestly, I think this would be more valuable than the AI-generated text, just saying! 😊 Any updates on when this might be included?
simsaur
  • February 15, 2025
I discovered this limit when I already designed 60 slides.. so now I think I have to transpose everything on Figma Design to prototype objects, I couldn’t imagine Figma Slides didn’t have this feature.
Eric_Fain
  • February 17, 2025
@simsaur I had the same reaction though not as far in as you.
Generally if you are using slide transitions/smart animations to manage individual elements you are also creating a horribly bloated and difficult to manage presentation.
Simply having objects to appear on click does seem like a basic requirement in any presentation tool I can think of other than Prezo.
HowardHughes
  • February 26, 2025
This feature should absolutely be the next one implemented. The lack of it forces some people to use PowerPoint rather than Figma Slides. I agree with the guy who says Figma Design is currently better for presentations than Figma Slides.
Jon Perl
  • March 6, 2025
I think the duplicate slides animation approach could work well, if the extra animation slides didn’t count as a new slide but rather a “transition slide” -- they are all grouped together, and you didn’t feel like you were adding 2x as many slides to have animations.
Chris_P1
  • March 10, 2025
this also means that if you want say 3 animations within the same slide content, you need 3 slides with varying content according to your needs, sort of as a hack. This seems easy, but you better have your content PERFECT before duplicating your slides twice. If you need to go back and make any changes or additions to any of the static elements from slide one to three, you’ll probably need to start over.
Margot_Gabel
  • Active Member
  • June 13, 2025
We need action builds like in Keynote to make Figma Slide truly powerful!
https://support.apple.com/guide/keynote/animate-objects-on-a-slide-tanf96d92cb6/mac
Tomasz_Banas
  • September 8, 2025
+1 — Yes, please.
