No way to define links to other pages in Figma Sites component (Using MAKE).
  • July 2, 2025
  • 130 views
Glenn_Cahill
So I have created a simple form component and used MAKE to create a working version suitable for prototyping (This allows me to have full text entry and validation).
The biggest issue is I am unable to tell the ‘Submit’ button to navigate to the next page in the prototype.
Even if I tell MAKE to navigate to that page it just doesn’t seem to work.
Does anyone have a work-around or solution to this problem?
Glenn_Cahill
  • July 2, 2025
It appears that if you create the link first (ie Create the form as an auto-layout design) then convert that to a make product you can tell it to maintain the link you’ve already created. But I do wish there was an opportunity to select in isolation the button in the code and tell it to navigate to a designed page in Figma Sites.
rtwill06
  • November 25, 2025
+1 to this feature request. Glad you found a solution for this OP. I’ve been trying to solve the same issue with a header component that I modified in MAKE. I’ll have to try this on my end now. Did you find that the link remained when using the component on other pages or did it break?
rtwill06
  • November 25, 2025
I can’t seem to replicate this solution. As soon as I click “make interactive with code” the pre-applied links break. OP ho were you able to maintain the links when making the component interactive?
