Anyone using Figma for prints ?
  • June 2, 2025
  • 127 views
ELEIOS
Good morning everyone!
I discovered figma in 2022 when taking a course on UI/UX design for the web — and I instantly fell in love with it.
Since then, I’ve been using it for everything, including print design — flyers, business cards, signage, packaging... you name it. It is a wonderful tool and more than enough to produce professional renders.
I’m only missing the ability to export PDFs with advanced print specs like:
  • Overprint settings
  • ICC profile embedding (like ISO Coated v2 300%)
  • CMYK color management
  • Bleed and margin controls
  • Spot colors / named channels (e.g., for varnish or Pantone inks)
I usually work around using third-party plugins — but it’s not ideal.
Anyone else here using Figma for print work? How are you handling these limitations? Do you use plugins like TinyImage or Pitchdeck? Or do you jump to InDesign/Illustrator at the last step?
Would love to hear your workflows — and maybe raise awareness for better native print export options in Figma 🙏
coodersio
  • Active Member
  • September 8, 2025
You can try the Print Layout plugin https://www.figma.com/community/plugin/1419316259939080556/print-layout-cmyk-exporting-rgb-to-cmyk-mapping-bleed-crop-marks-300-dpi , it's like a mini InDesign. Here are some video guides
coodersio
  • Active Member
  • September 29, 2025
Just to add: the “Printify | Print for Figma” plugin also supports:
  • ICC profile embedding (ISO Coated v2, FOGRA39, etc.)
  • spot colors/Pantone channels /Overprint.
That means you don’t lose color accuracy when preparing files for professional printers.
https://www.figma.com/community/plugin/1419316259939080556/printify-print-for-figma-print-ready-pdfs-with-bleed-crop-marks-cmyk-export-spot-colors
