New Feature: Version Control on Dev Ready
  • April 25, 2025
  • 65 views
Madi Williams
There’s a need from our engineer partners to maintain versioning of components within Figma. Right now, this process is SUPER manual. The Designer has to maintain a version number within the description box, for reference. And when making changes, we then have to update the description version number, and then secondly add that same version number to the dev ready notes so they can see it in the Ready For dev section (which is also hidden when opening dev ready under “Compare Changes”).
It would be amazing if there was just an automatic number 1.0.0 applied to the component when marked ready for dev in a library. And then it could be a button for the designer to determine which type of change they are making and just add the patch number and maintain that so dev can see that and the history of that change.
Sean Hills
  • April 25, 2025
I need this like NOW!
