Review updates dialog: Component navigation/update improvements
  • March 6, 2025
  • 21 views
Pepa_Linha
Hi,
  1. Updating components slows down the inability to browse other components from the open review detail of a component. I would also expect the possibility of browsing components in the detail.
  1. Furthermore, if I update all instances, a button to move to the next component appears. However, it does not behave in such a way that it moves to the next component, but to the first, which is strange.
    An example of use is if, for example, I have the first component in the change list, where there are 300 occurrences, but I want to skip it at the moment, I go to the detail of the second component, update it, but then I have to go back and deal with the second component again.
  1. I would like to see a button "Update all in this change/push/..." in the list of component changes. Now I can only update components one by one or all at once.
Thank you for checking the comment and I would be pleased if some (or all :-)) of them were implemented and I discovered them in one of the next versions.
