Slides Template - Retain nested sections & page animations
  • February 21, 2025
  • 24 views
Melissa20
I have a feeling neither of the following are possible due to the current flexibility of using template slides -- ie you can choose to use just a few slides from a template instead of using them all.
I’ve just published a large slides template for company wide use but realized it does not retain the nested sections or animations between slides. The deck has 91 slides so without the nested sections that appear under each title slide it’s difficult to manage.
I also have some slides that use variants of the the same component that I have set to smart animate between then to show the proper animation, but this is not retained in the template either.
Is it possible to keep either of these baked into the template? Thanks
